HamSphere 5.1 LIVE!!!
2025-07-26 12:36 |
Admin Registered: 17 years ago Posts: 1,062 |
HamSphere 5.1 is now live.
We’re thrilled to announce HamSphere 5.1 — a major upgrade that revitalizes the HF bands with life, realism, and dynamic conditions. You’re invited to log in, explore, and give us your feedback. Welcome to try it out. No need to download anything. This was a server upgrade only. Just use your normal HamSphere client- What’s New in HamSphere 5.1? HamSphere 5.0 is fading into history. Too often, new users logged in to hear nothing but silence or white noise — a dead experience. HamSphere 5.1 solves this by bringing the HF bands alive with an authentic and engaging soundscape. Info Beacons on Every HF Band Each HF band now features a global set of “Info Beacons” that simulate real-world propagation across regions: • +10 kHz – North America • +13 kHz – South America • +17 kHz – Africa • +20 kHz – Europe • +23 kHz – Asia • +27 kHz – Australia • +30 kHz – Oceania Example: 160m Oceania Beacon → 1830 kHz 20m North America Beacon → 14210 kHz These beacons announce region, band, power, and typical propagation paths — while creating clear peaks on the bandscope for visual tracking. CW Companion Beacons – Realistic Splatter Each Info Beacon has a CW twin, offset slightly higher in frequency to simulate bleed and interference: • +3 kHz – North America • +4 kHz – South America • +5 kHz – Africa • +6 kHz – Europe • +7 kHz – Asia • +8 kHz – Australia • +9 kHz – Oceania These CW beacons currently run at ~10 Watts ERP and may cause slight overlap — a deliberate effect to mimic real crowded bands. Lifelike QRMs – The Bands Are Alive To recreate real-world HF conditions, we’ve added diverse QRM sources, especially on 160m to 30m: • RTTY (Slow & Fast) • PACTOR • STANAG military bursts • Number Stations • DUGA Radar (Woodpecker) • Ionospheric Sweepers • Chirpers • Over-the-Horizon Radar 20m–10m bands remain cleaner, but QRM still appears occasionally — just like on real HF. General Info Beacons – System & Ham Radio History At the top of 20m and 17m, you’ll find informational narrations about ham radio and HamSphere itself: • 14285 kHz – Ham radio history (USA) • 18187–18191 kHz – HamSphere info: – 18187 USA (English) – 18188 Asia (English) – 18189 South America (Spanish) – 18190 Europe (English) – 18191 Oceania (French) These serve as key guides for newcomers and provide educational content about amateur radio. Live Lightning Simulation – Powered by Real Data You’ll hear real-time thunder crackles and static based on actual global lightning strike data from sources like Blitzortung.org etc. The closer a storm is to your virtual position, the more intense the effect — especially noticeable on 160–40m during heavy storm activity. More Accurate VOACAP-Driven Propagation HamSphere 5.1 uses minute-level VOACAP updates based on live sunspot data, creating band conditions that closely match real HF propagation patterns and the sun-spot numbers. Re-worked DSP HamSphere 5.1 now uses advanced DSP algoritms to enhance your simulated HF experience. AGC, Roofing filters, Fading Algorithms, Multi-Path simulation. Everything under the hood. |
