First CC-Line Plug-ins available
2026-05-23 21:09
Introducing CC-Line - The Next Generation HamSphere Plugin Series
We are proud to announce the first two plugins in the all-new CC-Line series - a complete redesign of the HamSphere plugin experience, built from the ground up with a modern dark dashboard aesthetic and real-time data.
MOD027 - PILE-UP MANAGER
The DX operator's best friend
Managing a pile-up just got a whole lot easier. The CC-Line Pile-up Manager gives you a real-time queue of calling stations, complete with country flags, DXCC lookup, dupe detection and one-click logging - all in a clean, high-density display that fits beautifully into your HamSphere rig.
Features:
Live queue of up to 6 stations with country flags, DXCC data and elapsed time
NEW, DUPE and N/DB badges - know instantly who you have worked
One-click Work #1 logs the contact and beeps confirmation
Skip, Clear Dupes and CLR ALL queue management
QSO rate bar showing contacts per hour
Worked Log showing your last 10 QSOs with band, RST and UTC time
Frequency display with RX/TX indicator
Automatic session reset on band change
Skin-aware layout - works with all HamSphere skins
Get it here: https://shop.hamsphere.com/product_info.php?products_id=322625
MOD028 - PROPAGATION GLOBE
See the world the way your signal does
The Propagation Globe transforms abstract propagation data into a stunning interactive 3D visualization. Watch the gray line sweep across the planet in real time, see where your signal can reach, and understand why certain DX paths open at specific times of day.
Features:
True 3D orthographic globe with photorealistic world map
Real-time gray line - day/night terminator calculated to the minute
Night side rendering with atmospheric lighting
Live DX spot with great circle signal path arc on the globe surface
Solar Flux and SSN data updated every 10 minutes
Active band display
Drag to rotate - explore the globe from any angle
Mouse wheel zoom - get closer to any region
Auto-rotation mode - watch the world turn
VOACAP propagation overlay, aurora oval, multi-spot display and signal coverage visualization.
Get it here: https://shop.hamsphere.com/product_info.php?products_id=323285
MOD029 - CC SSTV RX/TX
Send and receive images over the air
After 19 years of user requests, SSTV has finally arrived on HamSphere. CC SSTV RX/TX lets you exchange images with stations around the world using four fully supported modes, with automatic signal detection and rock solid sync even in poor band conditions.
Features:
Martin M1, Scottie S1, Robot 36 and Robot 72 - full RX and TX support
AUTO VIS detection - enable once and the plugin identifies incoming modes automatically
Live image building - watch your received image appear line by line in real time
Load any image for TX and transmit with a single click
Built-in PTT control and modulation level slider
Save received images as PNG with one click
Advanced DSP sync recovery - stays locked even at low signal levels
Verified compatible with MMSSTV and all major SSTV software
Get it here: https://shop.hamsphere.com/product_info.php?products_id=323295
MOD030 - CC PSK31
Decode and transmit PSK31 digital mode
CC PSK31 brings full BPSK31 capability to your HamSphere station - no external software, no sound card routing, no complicated setup. Click a signal on the waterfall, watch the text roll in, type a reply and hit Enter.
Features:
Live FFT waterfall with adaptive AGC and heat-map color grading
Click-to-tune with sub-bin FFT interpolation for precise frequency placement
AFC/PLL with lock indicator - automatic carrier tracking once engaged
Full TX with keyboard input and four macro buttons (CQ, RST 599, QRZ?, 73 SK)
TX monitor sidetone - hear your own transmission as it goes out
Filter bandwidth selector (100, 250 and 350 Hz) with visual waterfall overlay
Squelch - suppresses noise decoding when no signal is present
Live SNR, IMD and WPM signal stats updated in real time
Save received text to timestamped file with frequency and UTC
Clear RX and Clear TX buttons for quick housekeeping
Real transceiver frequency display in the header
Auto sample rate detection - adapts to your audio configuration
BPSK31 at 31.25 baud with raised-cosine pulse shaping and full Varicode character set
Get it here: https://shop.hamsphere.com/product_info.php?products_id=323325
These plugins are available now in the HamSphere Plugin Store. More CC-Line plugins are in development - stay tuned.
73 de HamSphere Dev Team
