European Top-40 Net Mon, Wed, Sat 7040kHz, 21:00 UTC
2023-08-25 02:59
European Top-40 Net
When? Every Monday, Wednesday, and Saturday starting 26th August @ 21:00 UTC
Frequency? 7040 kHz
Join us as we delve deep into the world of Ham Radio, utilizing the remarkable skywave (NVIS) propagation. This Near Vertical Incidence Skywave (NVIS) mode allows signals to be radiated vertically, giving it an almost straight-up and down trajectory. This unique characteristic enables consistent and clear short to medium range communications, often likened to 'armchair quality' reception.
Whether you're keen to discuss HF, the nuances of Net, explore the virtual realms of HamSphere, or engage in technical discussions on the solar cycle and propagation, this is your platform. For best results, we recommend using the Lazy H antenna or the 2-Element beam.
Fuel your passion, expand your knowledge, and connect with fellow enthusiasts. See you on the airwaves!
https://www.facebook.com/groups/hamsphere.european.top40net
