User list
2023-02-15 12:54 |
Is there a user list in the plan? | |
Re: User list
2023-04-06 20:17 |
I got an answer from the support and I am publishing a link here for those who saw my previous post. 73 Sami
https://www.hamsphere.com/addon.php?0,module=user_list |
Re: User list
2023-04-07 11:07 |
this list is wrong !!! you have to remove RM1, OSR remotes, special stations (HE and others...)... It would be great if there were more than 400,000 members and at least 1% active !!!!!! | |
Re: User list
2023-04-07 12:00 |
DR OM Emeric,
I understand that. It is more of a list of previous subscribers, but if you need the name of somebody it is useful. 73 Sami |
Re: User list
2023-05-16 12:46 |
Hello DR OM's
My post from 2023-04-06 20:17 does not valid anymore because it was connected with Hamsphere 3 Web site which is terminated. So sorry, now we can find the name connected to some call sign only if we type the call sign in the log book and click Log QSO, when we see the name then we should click on the reset button. Maybe in the future, we will have some other way to do this. 73 Sami |
Re: User list
2023-05-18 08:10 |
Hamsphere can already do what you require.
However. Alas, you have to purchase the plugin which does it and then add it to you transceiver. https://shop.hamsphere.com/product_info.php?products_id=25904 |
problemes avec cartes qsl ham 5
2023-06-11 15:56 |
14HS5823 **depuis le passage a hamsphere 5 ,voici mon probleme **impossible de recuperer mes cartes qsls reçues sur hamphere 5,sur 88 pages c,est toujours la meme qsl card qui apparait soit environ 88 pages x9 =970 cartes perdues **cela fait 2 fois que je contact le hs support ,probleme non resolu a ce jour ,dans l,attente ??? | |
support Hamsphere sur Mobile
2024-04-01 21:10 |
bonsoir je constate depuis quelque temps sur l'appli Hamsphere 5.0 on ne plus acheter élément sur l appli PK.......
F4LDO |
