FREQUENCY TO TEST AUDIO
2023-06-27 15:52
Hello all,
Is the frequency to test audio ((1.823.45) always avalaible ??(seems not)
Thanks for information please.
Re: FREQUENCY TO TEST AUDIO
2023-06-28 17:51
That is good idea, it will useful.
2023-06-28 17:52
SRI Will be
2023-07-02 10:06
14HS398 Wrote:
> Hello all,
Bjr aucune frequence abilite pour autotest audio est afecte a ce jour sur HS5 .Seul reccomandation niveau de TX avec notre SMeter le niveau de ALC ne doit pas se arrete audela du N3 dans le segment ALC si vous avez le LED sur le SMeter le niveau Rouge est la limite pour la calibration du niveau microphonique il n est faut pas rester dans la zone apres le N3 ALC pendent la transmission le 3 LED Rouge ne doivent pas rester allume constament pendent votre transmission .Calibration de ALC comme le Transceiver reel .
2023-12-30 04:10
You can test: https://mictests.com/
73 de 153HS1129/Len
2025-03-28 09:12
Quick and easy solution to test one's modulation: assuming you are a subscriber signed in to HamSphere on a PC, request another trial subscription from either same town or nearby town on a different email address, sign in with those trial subscription credentials on the mobile app, on mobile data (not wifi on the same home network as PC), turn your power on the transmitting station all the way down to one or two clicks (equivalent to 0.5-1 watt), and transmit, preferably on an HF band with little or no activity. Say something, like, "This is [your callsign] testing." If your modulation is set correctly, you will hear yourself on the trial subscription app. I think this is a valuable enough tool to go ahead and pay for two subscriptions at a time. There may be some subscribers on here with more than two! (Edited after reading rules) Do not open multiple accounts. My mistake.
