Rag Chew Net Report 2021 04 14
2021-04-14 14:17 |
The HamSphere North America 40 Meter Rag Chew Net met on Wednesday the 14th April on Frequency 434.500 Mhz at 01:00 UTC with 16 HamSphere Operators checked in:
VE3OHS - WAYNE (ON) NET CONTROL 2HS1189 - RIK (IN) NET LOGGER VA7FT - TIM (BC) SATURDAY NET CONTROL NA1NA - DAN (MN) 2HS6874 - ROB (FL) 2HS1980 - SUNIL (CA) 2HS2265 - JOE (NV) M6INJ - PETE (UK) K3VIC - VIC (CA) 9HS3639 - GEORGE (ON) VE3FRM - GLENN (ON) VE3HO - GARTH (ON) KS1K - DAVE (FL) NET ADVISOR KI1WZB - JIM (WA) ASSISTANT NET CONTROL 2HS511 - DANNY (NC) 4S7DA - DENVER (LK) Sixteen check ins and this evening NA1NA asked a question about the Net Logger - during the net the Net Control works with the list that the net logger makes in a stand alone program called Net Logger (link will be given) as well with the Net Control Plugin available from the HamSphere Shop. The next session of this net will be on Saturday, April 17th at 01:00 UTC on Freq 434.500 (70 CM) for Check In and afterwards for Round Table or Discussion. Net Control will be VA7FT Tim and 2HS1189 Rik as Net Logger, do join them. For comments or questions please email: ve3ohs@gmail.com de VE3OHS Go Forth and Work Split. https://www.netlogger.org/ link to Net Logger |
Re: Rag Chew Net Report 2021 04 14
2021-04-14 15:01 |
Nice
Thanks |
