Question/Discussion Points for North American Rag Chew Net on Wednesday 17th May 2023 @01:00 UTC from M6INJ(Pete)
2023-05-12 14:40
The next session of the HamSphere North American Rag Chew Net is scheduled for Wednesday May 17th at 01:00 UTC on 70CM (434.5).
The last few nets we have had excellent numbers of check in 21 and 19 on two successive nets and the Managment Team thanks you for your support.
M6INJ - Pete has suggested the following topic for discussion:
If HamSphere were to change HS5 from defaulting to 6m on launch or start up, and change it to the last band you operated on, how likely are you to stay on that band?
If the default start remains 6m, it is my opinion this is why Operators remain on 6m and not moving to the HF bands.
What are your thoughts and opinions on this?
Join us for this round table discussion on Wednesday, May 17th, at 01:00 UTC on 70CM (434.5).
de VE3UWA
