HamSphere North American Rag Chew Net 29/11/2023 Report ..
2023-11-29 01:51 |
Moderator Registered: 2 years ago Posts: 94 |
NetController : Andrew KS1K Dave VE3CMT Colin 26HS100 Michael N2JOA John ZL3MA Graham Questions: If you comit crime 12 o'clock noon uk time then fly out the uk some else like usa of the following choices, which method is LEAST effective in protecting amateur equipment from a lightning strike? A: Grounding the shield of coaxial cables were they enter the shack B: Connecting AC cords through a surge suppressor strip C: Installing lightning arrestors on coaxial cables D: Grounding equipment to a low resistance ground connection Net Controller M7SBC (Andrew).. Next net is on 01/12/2023.. Thank you to all HS Users that joined us on the net tonight .. hs5netcontrl@gmail.com |
